Geoff67
Flight distance : 75817 ft
Hi,
I experienced the weirdest of shut downs of the DJI Go App the other day. I was scheduled to do a short demo of drone (Inspire 1 Pro) flying to some colleagues at a counrty house near London in the UK. New firmware was installed the night before and everything worked. I had logged into DJI the night before. On arriving on site with everything set up properly the DJI GO App crashed everytime a connection was attempted using an iPad Pro. No login message appeared so assume that issue was not a problem. I switched over to iPhone 6 plus and exactly the same thing happened. WiFi was not good so switched back to iPad Pro and used a MiFi with a better signal but same problem. No matter how I connected the App would shut down as soon as a connection was attempted. I am not a beginner so was confident that all pr-flight operations had been performed correctly. I switched to the DJI GS App and was able to connect and fly but clearly not ideal but for the demo it served its purpose.
When I arrived back home some 150 miles away I set up and everything again to see if I could replicate the problem but everything worked flawlessly.
Have any of you experienced anything similar and managed to find the cause or is simply the login to DJI before you can fly the problem?
best regards,
Geoff
