Donalbain
Flight distance : 208504 ft
Hi!
I use the remote via OTG to connect my Oneplus One with LineageOS (Android 7.1.2) to the Spark, with works fine in terms of connectivity … BUT …
The DJI Go 4 App crashes ALL THE TIME. I have at least 3-4 crashes during 12 Minutes flight. Every flight! The app is horribly broken.
The error logs are not identical, but they usually start with java.lang.OutOfMemoryError pthread_create (1040KB stack) failed: Try again
This also sometimes happen when I'm not flying, but only reviewing the flight logs. Also I noticed that the phone heats up rapidly and battery usage of this app is extreme. Sometimes 40 to 60% loss per hour. I tried to delete cache, user data, re-installed the app, started it as only app in flight mode, no progress …
I put all the error logs in my dropbox:
https://www.dropbox.com/sh/sre01a0snyupcgk/AACYpzVUG5xpcbwZCsYzdJsLa?dl=0
(The connection to the Spark works so far, fortunatly, It just stays in the air until the app is restarted or I can move with the RC alone)
Please, DJI, fix this! In the few minutes when everything works, it's really great.
