Limited distance/altitude
2091 13 2017-7-15
fans325ce6ff
Flight distance : 5418609 ft
37 successful flights with no problems. Excellent distances and altitude. Suddenly tonight, I reach max distance/ altitude of 90 ft and drone will not go past this limit. I am not in beginner mode and distance/altitude are set to max on GO app. Have no idea what's going on or how to fix. Suggestions appreciated. Thanks.
2017-7-15
JTPhotographics
Flight distance : 11158 ft
New update enabled a geo-fence. Are you logged in to the app?
2017-7-15
JTPhotographics
http://www.dji.com/newsroom/news ... nd-firmware-updates
2017-7-15
Highasakite
Flight distance : 1423930 ft
fans325ce6ff, so just log out of your account, then log back in and you should be good. Safety First! Ken.
2017-7-15
Lucas775
Flight distance : 50642090 ft
Try logging out and log back into the account after update.
2017-7-15
fans325ce6ff
Logged out, updated app, logged back in, took a very quick test flight and I think the problem is solved. I'll test again tomorrow. Thanks everyone.
2017-7-15
PizzaCat
Flight distance : 104429 ft
I had this same problem occur today for me, and I've tried logging out and back in and reinstalling the app. For some reason, this did not help. What else could I do to fix this?
2017-7-16
Peterx
Flight distance : 1499708 ft
What version of Go app and/or FW is it ?  I have the FW 1.9.0200 and the Go app 3.1.18 without any issue with range. I´d update the Go app first and then the FW for the copter after that i ´ve been log out automatic and had to log in. The beginner mode was in and i took off this. The limitation was gone.
2017-7-16
Salmonslayer
Flight distance : 100220 ft
Where do you find what go app version you have installed ?
I have had the same limiting flying after I had no problems with prior. I have logged out and back into my go app but have been unable to fly my P3S , so dont know if it resolved it.
Also, I noticed when I logged in  is didn't default to begginer , isn't is suppose to after u log out ?
Clint
2017-7-21
Peterx
Power all devices on,RC AC and then phone/tab with Goo app tab the camera bar and then the upper right corner the settings. Slide up to the info. Tab on it and you can read the FW AC > 1.x.xxxx FW RC 1.x.xxxx SN xxxxxxxx and then the go app version 3.x.xx.  I did not log out of my own,the app did it for me and then i had to log in.
2017-7-22
chechoaccietto
Flight distance : 254347 ft
Argentina
I'm having the same problem, I logged out, then logged in. I erease the apk, I installed again.. and still the problem.. I don't think it's a hardware problem.. I've been reading many people is having the same issue..
2017-7-24
Salmonslayer
So your saying after I hike 6miles to get to a safe place (per Canadian law) to fly my AC, I find out I'm limited to the 30/50. And can log out of my go app but can't log in because my tablet doesn't have internet or a WiFi connection, Im stuck with the 30/50, until I hike 6 miles back and connect to my internet and then hike another 6 miles back to my safe spot and find out I still... CRAZY I SAY!
2017-7-25
LooweeBee
Flight distance : 8983 ft
I had the same distance / height issue. I uninstalled the Go app, reinstalled the app thru Playstore,..logged back in and everything is working GREAT..!!
2017-7-28
x-acto
Flight distance : 837799 ft
Restart every thing and go to all default settings
2017-7-28
