Ale Reynoso Cin
Argentina
Hi:
So, while we are dealing with an HDMI output issue (waiting for DJI response), we are fine tuning our "ground station" for live feed to OB trucks:
We need to improve our radio signal. The slave RC must be close to the OB truck, and sometimes not in the best spot to use the stock antennas fixed to the RC. We are planning to connect two high gain dual band omnidirectional antennas and mount them in a high pole/mast. Are any of you using something like this? Wich brand of antenna/cable type/cable max. lenght are you using?
We are not aiming for extreme range. The farthest we can go is 500m, but we need the signal to be rock solid at every moment. And as the video signal goes straight to the slave RC (is that right, isn´t it?), we need to improve that signal (is not a problem if in the master RC we receive a frozen frame from time to time).
If you have some photos of your setup it would be great
Thanks!!
Alejandro
CinePilots
PD: I posted this in "Inspire 2 hardware" but I was not getting too much attention
I could not find how to eliminate that post
