danielsb
Hello, I bought a Freewell ND variable filter for my Osmo+. Something was wrong with my order so I receive 46 mm filter. Before return it I check and it's exist a ring adapter. 46mm to 34mm (i dont remember exactly right now). If it works will be an advantage cause the Osmo lens will works on the usefull center of ND variable. Anyway the question is: the extra weight of a bigger filter and a ring adapter will affect the behavior of gimbal? engines? stability? Someone experienced it? Regards
