fans7e9fbb42
Flight distance : 547080 ft
Portugal
fansbb6ff3df Posted at 2017-7-16 05:25
I believe this may be firmware related. The same thing happened to me most of yesterday. At first I thought it was the cable connection to my phone. Then I started getting messages about firmware in compatibility between the battery and the remote. After updating the firmware, I flew with no problems for several hours.
However, later last evening, I began to have the problem again. I found that if I disconnect the cable from the side of the controller and reconnect it will work again for a few minutes. I have swapped out several cables and can find no consistent combination that works or doesn't work.
BTW, the disconnection is simply between the RC and the phone. It is not losing a connection with the aircraft. The controller still has full control of the aircraft.
Hey, i did full reset with firmware rc and aircraft, i use other cable now just my phone charger and it worked fine today!! no worries anymore.. i flew 3 batteries empty .. i also relinkt several times my control to aircraft. so i think these steps did work.. |
