I have sorts of pixel tasks only when I move the nacelle up low, a guy posted his problem on YouTube I have exactly the same thing (info ke filme in 2.7k 25fps)
https://youtu.be/ ycJHQy93gyY
Do I want a lot from the mavic camera? I can go too fast with the nacelle (set on 12 at home)
I am not able to watch this video for some reason. Received a 404 error when I am trying to open the link, can you double check it and upload it again?
Doesn't look normal. Never scene this on mine. Not sure if it is because of high frame rate and quick movement and bitratelimitation of 60mbps. Try a test on 2.7K If you still see that. Also test another SD card.
