Urgent issue: Logged in but can't fly past 30m and 50m
21601 36 2017-7-17
xr280xr
I updated my phantom 3 standard to the 1.9.20 update a few weeks ago. I didn't know at the time that it required a log in, but I was logged in to the DJI Go app on my iPhone. I took it out for 3 or 4 test flights at a park near my house in Dallas and flew it around without any problems. Now I'm on the trip to the Colorado Rockies which I actually bought the drone for, and I get up here and it won't fly farther than 50 m or higher than 30 m! I have an extremely slow 3G connection that let me discover the login requirement. I've tried logging out and logging back in in the app and logged into the website but nothing works. I am not in Beginner Mode and I have mac distance disabled. Max height is set to the default which I think is 120 m. I need it working now or I'm going to miss all my opportunities to shoot the shots I lugged it all the way out here for. Can anyone help? I'm on app v 3.1.1. I can't  update it due to apple's criminal policy of limiting my "unlimited" data plan by requiring wifi to download the app. Why is it being limited and is there anything I can do?
2017-7-17
WD9EON
Flight distance : 686886 ft
Would it be possible you are in a restricted fly zone?
2017-7-17
xr280xr
Not that I can tell. I looked them up before heading up here and there was nothing for miles. I'm outside of Crested Butte, CO at Taylor Park.
2017-7-17
Tom24nh
Flight distance : 174239 ft
Just had the same thing happen to me. I flew after the update and everything work fine was able to go 400 feet. Today I tried flying and was only able to go 93 feet (30 meters). I think you need to log out of DJI go app and log back in. I will try flying again after battery is charged and let you know if that works. I believe I read that you have to do that.
2017-7-17
xr280xr
I've tried that several times with no luck. Let me know if it works for you. I hope it does.
2017-7-17
Tom24nh
http://www.dji.com/newsroom/news ... nd-firmware-updates Here is the information about the update.
2017-7-17
Phantomski
Flight distance : 14869882 ft
you do have to have to have internet access the first time you power on the motors.. u do not neccessarily have to fly, but make sure u start up in an area where you got internet.. let be a few.. then see if this happens again/still....
2017-7-17
Highasakite
Flight distance : 1423930 ft
All you have to do is, sign back into skypixel and ALL will be RIGHT my friends! Just sign back into skypixel. Safety First! Ken.
2017-7-17
xr280xr
In at least one of my flights at home, I had internet access. I did a facebook live stream for one of them. In my flights here, where it is not working, I have this slow connection. But you are only supposed to have to log in once. After that, no connection is supposed to be necessary. So it should've been taken care before I got here, but even if it wasn't, I'm connected here on 3G.
2017-7-17
xr280xr
Sorry, highasakite, but that is not the case. I am signed in and have signed out and back in multiple times. Please everyone read the OP before posting.
2017-7-17
Tom24nh
xr280xr Posted at 2017-7-17 16:07
was having the same problem, log out log in still wont fly above 100 feet. I had to connect to phantom with app then I connected to wifi and it showed app needed an update, I updated and tried again still had same thing. I then logged out of app and tried to connect to phantom and it said I needed to log in to app. I then logged in with wifi then changed over to phantom wifi and did a test flight and it work fine. I think the trying to connect without being logged in did the trick, try that i hope it helps.
2017-7-17
DJI Diana
Flight distance : 2408 ft
Have you tried to re-install the APP, then log into it , see if it works?
2017-7-18
Xian Onemanshow
Flight distance : 5384334 ft
Hi guys
i am having this issue since i upgraded my aircraft to the latest FW , i just downgraded it last night , i hailed like a few meters  but not that much , i tried 1.6.80. 00 without any changes
now did a couple of tests with 1.7.90 , same thing , will give it another try again later today , for some reason its a large known issue on the P3 S .
2017-7-19
Bramz
Flight distance : 49327 ft
Denmark
I'am experiencing the same issues. At first I thought it was antenna issues, but it is too consistent across different spots to be antenna issues.
Whenever I get 30m-ish in altitude and 50m-ish in distance (which fits with the 1.9.20 firmware specs) I loose RC signal. It goes from 5 bars to 1/0 bars in split seconds. The video feed is in the meanwhile perfect. Is is tried across multiple spots to avoid interference, buildings, trees, etc.
I have tried the following without any luck:
- Relink RC
- Logout and login to DJI Go (both with connected and disconnected from the drone)
- Delete and reinstall DJI Go
- Adjust antenna position
- Calibrate IMU
Is there any news on this matter?
2017-7-19
Yorkee
Flight distance : 306916 ft
I am having the same issue. I tried to reboot my phone, app everything and when I take-off I can only fly 30 m up and 50 m away (really sucked when I did a 2 hour hike to a nice waterfall and was hoping for  very cool pictures). I tried to log out and log back in and still it does not work. I do not understand why they implemented this stupid rule. I feel like having my drone in a cage now. Please DJI fix this stupid bug. Thank you in advance.
2017-7-19
xr280xr
I got it working. I found a campground with wi-fi so I was able to update my iPhone DJI GO app from 3.1.1 to 3.1.13. When I started the updated version of the app, it asked me to log in, then took me on a tour as if I had never used the app. I checked my settings and they were all correct but Az apparently they can get reset (like enabling beginner mode) for some people. I then left the wifi area and went back to my camp and tried it out and it's distance and altitude were finally unlocked.
So it appears there is an undocumented requirement that you need to update the app to use this firmware!
I had been in email contact with DJI and they had me going in circles checking settings and recalibrating the IMU repeatedly.  They never once even suggested that the app might be the problem. I was very lucky to find wifi. I hope this helps some people.
2017-7-19
xr280xr
Thanks for your help Tom24nh!
2017-7-19
Yorkee
I just checked my DJI GO App and it wasn't the most recent one. I updated it and now I get a message: Please sign in with you account before using app (I did not get this message before the update). I have a good feeling about this. I am gonna give it a try tomorrow and let you know. Thank you xr280xr.
2017-7-19
stuka75
Flight distance : 85682 ft
there seems to be some confusion over the phrase logging in. Once firwmware is updated, DJI  must be notified(logged into) via the app on internet to release the p3 range limitation. sounds like many are calling opening the app to logging into the app?
2017-7-20
Chris Edwards
Flight distance : 91696 ft
on the update release notes it states updated fly zone safety that you will be required to sign in first or the limit is 50M/30M distance
it sucks
2017-7-20
xr280xr
Stutka75, logging in on DJI GO 3.1.1 did not unlock the restriction.  I understand the difference between opening the app and logging in.
2017-7-20
Yorkee
I went to fly my drone this afternoon and it worked well. So you need to make sure that you are having the most up to date version of the DJI GO App (I did check manually by going to Google Play Store, search: DJI GO App - Update was available. I believe, I have version 3.1.8 now).  After that I just logged out and logged back in. Thank you very much xr280xr.
Side note: App did crash couple of times during my flight. Exactly what I was reading when I was googling this problem.
2017-7-20
fansbd169b83
Flight distance : 66585 ft
DJI Diana Posted at 2017-7-18 00:50
I had  similar issue and did exactly what you suggested and it now works great. Re-install or update the DJI Go app. Thanks, very happy with the product
2017-8-9
Rene Jensen
Denmark
use litchi and yourproblems are gone.i only use the go app to calibrate imu.when flying i always use litchi app who is worth every penny.and i am still on 1.7.9 firmware and i get about 900-1000 meters with it and about 1300 meters with windsurfer parabole.
2017-8-10
DJI Diana
fansbd169b83 Posted at 2017-8-9 22:42
Glad to hear that, hope you can enjoy the drone, safe flying.
2017-8-11
G_Sig
Flight distance : 9109311 ft
Iceland
Rene Jensen Posted at 2017-8-10 01:00
It is your FW 1.7.9 not Litchi that save you. There is the same limit both in Litchi and Go apps. Both apps are supposed to work after you log in to your DJI after uppdate of FW.
2017-8-11
Rene Jensen
Denmark
firmware 1.7.9 and newer has range issue with litchi i get 1300 meters with windsurfer parabolic
2017-8-12
G_Sig
Iceland
Rene Jensen Posted at 2017-8-12 06:22
I think 1.5.70 is the best we can get now. I have one P3S on that FW  and other on 1.9.20 with Argtek mode and both go about same distance 1600m - 1700m .
2017-8-12
Charbray
I had this same issue. I purchased my drone for a remote trip (no phone/internet reception, no "no fly" zones, no interference, nothing but desert). Couldn't get the drone to fly past 30m from me, height or distance - it would lose RC signal and RTH. Did that since new, and I had updated the firmware straight out of the box.
For me, reinstalling the DJI Go app AND relinking the RC with the drone seemed to fix the issue. I guess I was lucky.
2017-8-15
DJI GO PM Team
DJI R&D Squad
Sorry for the trouble. If you update the firmware, please update the APP to over 3.1.12 if you use iphone, and 3.1.6 if you use android.
2017-8-16
DronerX
Flight distance : 488192 ft
Here's a minor twist to all these very similar stories.  I just upgraded the app (IOS) to 3.1.15 and did the log in for the first time.  I took off with no issues and was about a 1km away when I saw the 30/50 message for the first time!  The message persisted on my screen for a few moments and then disappeared.  I had to effect on limited my distance or altitude.  Weird!
2017-8-23
R&L Aerial
Flight distance : 298100 ft
DronerX Posted at 2017-8-23 16:06
Same here, I get the warning every start up but goes away...
2017-9-3
Betamace
Flight distance : 2133 ft
Chris Edwards Posted at 2017-7-20 09:39
it sucks
I get a warning message on the app's camera screen because I live a short distance from a private air field that was FAA declared in 1962. It's always been a farm, there's no tower, hangar, fuel, lights or even a windsock. But they do grow nice big tomatoes. Where the 1800x250 foot turf runway had once been now sports row after row of veggies..... and on my property I can't fly my drone higher than the trees in my back yard.
2017-9-3
fansba54784f
Flight distance : 21217 ft
Turkey
V1.11.20 release Notes states that unless you logged in to DJI, you are limited to 30m/50m: What’s New? 1. Updated No Fly Zone Management. 2. For increased safety, the flight is restricted to a height of 30 m and distance of 50 m when not connected or logged into the app during flight, including DJI GO and all apps compatible with DJI aircraft. 3. Fixed an issue causing occasional ESC self-diagnostic testing failure. Notes: 1. Make sure you restart both the aircraft and remote controller after updating them to the latest firmware. Otherwise, video downlink may be unstable. Re-link the aircraft with the remote controller if they are disconnected. 2. Please note that firmware update may reset various Main Controller Settings, such as the RTH Altitude and Maximum Flight Distance, to factory defaults. Before the update, take note of your preferred DJI GO settings, and readjust them after the update to suit your preference. 3. Requires the DJI GO iOS app v3.1.12 or later, or Android v3.1.6 or later, otherwise the flight is restricted to a height of 30 m and distance of 50 m.
2018-1-1
djiuser_anbSuHA
Flight distance : 34839 ft
Panama
That happens for two reasons 1. You may have a problem with the control antenna 2. You are not registered with your email account. I recommend you register. or I recommend that you enter the dji.com online support page and make the query.
2018-1-2
djiuser_anbSuHA
Panama
2018-1-2
fansfba34a03
I have a standard phantom. I cannot fly past 30 meters. It also,says i have IMU error. Ive calibrated. Ive reset. Ive reinstalled the app. Finally, it says im in beginner mode. im not. Im gona smash this POS. Help please.
Thanks
Joe
2018-9-16
