Data Logger Error
JasLau Prod
Flight distance : 298310 ft
Curaçao
Can some body tell me what i have suposed to do with my phantom 4
the error msg is:1. Data Recorder Errors 2. Contact DJI Support If it persists after restart.
PLZZZZ HELPPPP MEE
2017-7-18
DJI Thor
Flight distance : 13602 ft
Did it persist after reboot the drone? What firmware are you using? Is it the latest firmware v02.00.0106?
2017-7-19
EduBaeta
Flight distance : 543885 ft
Brazil
Try to change the sd card.  My issue was solved doing this.
2017-7-19
JasLau Prod
Curaçao
thx mow i have problem Camera Sensor Error
2017-9-20
DJI-Mark
JasLau Prod Posted at 2017-9-20 11:13
Sounds like a possible repair. If you have not done so, can you update to the latest firmware? If you have, can you contact Customer Service and set up for an evaluation?
2017-9-20
JasLau Prod
Curaçao
DJI-Mark Posted at 2017-9-20 12:12
I have change a part called camera sensor but it is the same problem. i have update my firmware and is the same.
2017-9-20
DJI-Mark
JasLau Prod Posted at 2017-9-20 12:41
That would not be an easy part to switch as many of the repairs require specific software that would not be accessible.
2017-9-20
