Ex Machina
Flight distance : 1806362 ft
Sparrow Posted at 2017-7-19 21:05
@all, I did shoot all video in tripod mode. Inside it helps a lot, but doesn't help with the shocking video unfortunately. I uploaded the whole video and can be viewed below. Especially at 27 sec it is very obvious. Will a higher frame rate help? And which shutterspeed? And then in the video editing program, which frame rate do you use on your timeline?
Here is the whole video
I think if you want to pan that quickly you need higher frame rates to keep it smooth. Unfortunately, there's some quality loss with the 60/96fps 1080p modes, but it might be good enough for your purposes.
Also, the cinematic-feel people claim the shutter speed should be a multiple of your frame rate, which might be problematic to attain indoors, but fwiw. |
