Timelapse app
PJElrick
Flight distance : 793317 ft
would you happen to know if there is a way to do a timelapse with a PH3a over a few months?
that the drone will return to the same spot every time i return to the same area!
2017-7-19
Aerial-Image
Flight distance : 1452408 ft
Nice idea - use something like AutoPilot - and a saved mission, that can be re used like - TARGET or  ZIP-LINE - but there will be slight  changes in position as the gps can be 1-2metre or so out.
2017-7-19
Twente
Flight distance : 13734 ft
Do you want a static timelapse or a moving one?
I'm currently using litchi to film the progress of the build of our new house. Using the same gps mission every time to fly around the buildsite. If the house is finished I'll edit all the clips to view the build in timelapse.
2017-7-20
