hallmark007
Flight distance : 9827923 ft
Hi Craigoliver, sorry to hear about your spark, you should be able to find it, it looks like it crashed 290 ft , if you play back your flight on your app there are coordinates just above play button.
Did you take off near any steel or metal objects or from concrete which usually has rebar in it, so many fly aways are caused from this type of thing, it won't matter if you calibrate before flying , if there is any form of magnetic interference on the ground you take off from.
Bobesh is right about conflict between compass and gps compass is dictating which way AC is heading gps is trying to take command from you or hover, gps just gives up and AC goes into Atti mode, IMU can't correct heading and aircraft takes off.
It is unlikely you got compass problems in the air, unless you flew close to metal roof or power lines. Maybe you have care refresh if you have use picture in your airdata and coordinates to help you find your spark.
Good luck. |
