solentlife
Flight distance : 1087530 ft
Latvia
kangier@macokc. Posted at 2017-7-20 19:09
Thanks for the reply. Yes, it came with the P3P. I just updated the firmware on the drone yesterday. I tried to shut down the entire system and still get the error.The other battery doesnt give the error and seems t work fine.How do I update the battery?
As long as the new FW bin file is still on the SD card in the root - it will automatically update each battery that needs it when you switch on ,,, it only takes a few seconds and you won't even notice it.
Its why I don't remove the bin file ... its only a few mb's and takes up hardly any room. Of course if you format / erase the card as some advise - then you need to download the FW file again for this ...
One thing that strikes me is your error does not say to me Battery FW ... it says something else ... which could be bad contacts or something ...
Its not unknown for the two sets of contacts to get grimy etc. A bit of contract cleaner (plastic safe of course) and a cotton swab can sort that. It only takes a spec ... even DJI actually mention it !!
Nigel |
