Recski
Flight distance : 231142 ft
Brazil
Mark The Droner Posted at 2017-7-22 03:21
DIY: Take the top off and check the GPS module plug and that it's inserted correctly. If it seems okay, inspect the module in the lid, especially the fragile porcelain antenna which may be broken or cracked. The antenna can be replaced rather than replacing the whole module. You tube will have videos on how to take the top off, etc.
Know that you may lose your warranty if you DIY.
Okay. I do need special tools to remove the lid off right? I bought this drone second hand, so no warranty from DJI. |
