jim.williams
The phone will also be hot because it is being charged by the battery in your controller, which, btw will cause you to have to recharge your controller sooner. Personally I wonder if the reason a lot of folks are seeing an increase of range, particularly IOS users, is due to the fact that the OTG connection forces the controller to 2.4 ghz instead of 5.8, which it (at least for me), will normally set itself up on. In general, 2.4 has better propagational range than 5.8, unless of course you are in an area where 2.4 is very congested across the band. With the OTG connection on IOS, you also lose the functionality of being able to look at noise levels on different channels and switch to a more clear channel. I am really not sure this is such a wonderful thing to do. It really needs a very controlled test IMO.
