hallmark007
Flight distance : 9827923 ft
Hi Cassettespark, looking at your log, two things you either picked up magnetic interference from the ground , were you taking off from concrete or was there metal close by. This can have serious effect on your compass, you may not have realised this when you were taking off and you don't always get a warning, or you may get a warning to move your spark because of interference, you could have also picked it up in the air if you were flying close to electrical wires or steel roof etc.
Because your compass is completely of the heading of the AC, while you are giving commands to go one way compass is pulling spark on its heading, gps gets confused basically gives up and spark goes into Atti mode this causes it to move on the wind any stick movements will increase the speed almost impossible to control raising the altitude may help avoid crash but unless you get gps back and try RTH , in such an area where spark was heading for buildings rather than down the beach probably impossible.
Regarding warranty, I have seen one similar case here where dji have given a warranty, I don't have any information why and dji are very protective of giving out this information, a bit ridiculous but if you get a warranty then I'm sure this is paramount for you.
When you send drone back, once they receive it get on to a mod here and try to get them to escalate your case, I will send you a link which might help you avoid this happening in the future.
Good luck.. |
