DennisMurry08
Flight distance : 5948264 ft
Let me pick a little bit....Look at your First and second level battery alert...with those settings you will crash...first level should be around 22V and second at 21.5 (everyone is different but thats what I use). This means the LED will start flashing yellow at 22V and Red at 21.5....and that means you should be landing. Next on the RC tab, change the "Manual" choice to "Atti"...yes, you will have 2 Atti's and a GPS....next, what radio are you using? Depending on what that is will depend on if you choose DR 16 or D-Bus....I would also like a clip on your Aircraft tab and then your channel mapping. Did you do a "stick calibration" in the assistant? But the first thing I'd do is fix your battery level, change the Manual to Atti and change to DBus. Then do a stick calibration and see if it starts. |
