CuaC
Flight distance : 369626 ft
Hi! Let's see if we can help you identify your issues. First of all, you can check the status of the compasses by clicking on the [...] menu (top right corner) and then first row (drone symbol) go to Advanced, Sensors state. Over there you'll be able to see what the readings of both your IMU and your Compasses (it has 2) are giving.
To learn how to calibrate, there are plenty youtube videos that can help you out, but lot's of them are also WRONG (people rotating the drong the wrong way, turning it the wrong way...) So let's draw some guidelines here:
-Unfold the arms prior to everything and remove the gimbal cover/clamp.
-Put the drone on the ground. Turn on remote, turn on the drone and wait for it to initialize.
-Make sure that you're not wearing anything metallic on your arms (wristband, watch, etc..) If so just take them off during calibration.
-Make sure that you're on an open field with no magnetic interference. Concrete flors often have metal inside. A table , your house... it's all full of metallic things that can lead to a false calibration.
-Once you're ready, start the calibration and do the following:
--> Pick up your drone and put it horizontally. Rotate it clockwise, but make sure that the drone stays in the same position and rotates over there. The best option is that you rotate around the drone holding it steady, the drone will stay in the same spot and rotate, instead of rotating around with you.
--> When you get the green lights, turn it face down and repeat the process. Another green light will confirm the calibration.
Now you can go back to check the sensors state to confirm that the reads are good.
If the process never works, then you probably need to get in touch with support to send it for repair. |
