Testing ND Filters and why you need them for the Mavic Pro!
1868 9 2017-7-23
JoeCec
Flight distance : 3491430 ft
https://www.youtube.com/watch?v=17DOiTf4VWM&feature=youtu.be
In this video I am Testing ND Filters and why you need them on the Mavic Pro! ND filters are nothing new to photography, and in fact are a necessity if you are wanting to create a cinematic, buttery smooth film look. I go over my 3 heavily used ND stops and what you need to know about setting the shot according to your histogram. Whether you go with the polar pro, taco-RC filters or perhaps another brand of your fancy, you can rest assured you will get great quality footage at the proper settings and ND filter.
Mavic ND Filters: http://amzn.to/2tqTF3S
or http://amzn.to/2ucwvkY
ND 4 = two stop reduction
ND 8 = three stops reduction
ND 16 = four stops
ND 32 = five stops
The ND filters allow you to maintain more of a cinematic motion blur to the footage.
The ideal shutter rate is half the inverse of the shooting rate. So if you’re shooting at 24 fps, the inverse is 1/24. Half of that inverse is 1/48. Since the Mavic doesn't offer 1/48 you can select 1/50. Or for 30fps, the inverse is 1/30 and a half that is 1/60. Most cameras don’t have a 48 shutter setting, so most people go with 50 or 60 so that the footage has a distinctive cinematic motion blur.The general rule of thumb is to try to shoot at 24 frames per second or fps. This gives more of a film-like look, while 30 fps produces more of a “video” style of footage. But the shutter rate you select with that 24 fps plays a huge role in the overall look of the final product. If it’s too high, it can give the footage almost a brittle look. On sunny days, that’s a problem. In the absence of an ND filter, the shutter rate will jump into high gear in auto (or you’ll be forced to crank it manually), in order to obtain the correct exposure.
2017-7-23
Jenee 2
Flight distance : 7852129 ft
Quite a good explanation. I am sure there will be many users who find this information helpful.
2017-7-23
BumblerBee
Flight distance : 639764 ft
Norway
I've been doing photography for some time, and the use case for ND filters there is a bit different there. Thank you for bringing you the videography explanation for their use and for the explanation of the shutter speed/fps ratios.
2017-7-24
JoeCec
Jenee 2 Posted at 2017-7-23 22:02
Thank you.
2017-7-24
JoeCec
BumblerBee Posted at 2017-7-24 00:30
Thanks for watching!
2017-7-24
DonBishop
I have an aftermarket set of ND filters that overload the gimbal at start up.  I have to go through the start up process, then put the ND filter on.  Does this issue happen with the DJI ND filters?
2017-7-29
JoeCec
DonBishop Posted at 2017-7-29 11:42
I'm not sure. The ND filters I use are Taco RC.
2017-7-30
Lucas775
Flight distance : 50642090 ft
I still yet have to purchase me some.  Thanks.
2017-7-30
PROMOLOZO
Ive been hesitant on buying just yet because of all the posts ive seen elsewhere about the filters getting stuck or hard to remove. Wish they had one with a rubber connection
2017-7-30
JoeCec
PROMOLOZO Posted at 2017-7-30 13:35
The ones I purchased have almost like a felt or spongey inner liner that offers a secure pressure fit. If it were rubber they would never come off and would damage your Mavic camera more than likely. here's what i use. http://amzn.to/2uP97bM
2017-7-30
