I'm curious about the information in the left column. It shows that I have flown 221,313 feet, but in DJIGO4, it shows that I have flown 725,909 ft. I have sync'd successfully with your servers.
So, why is the feet flown number different in this forum than it is in DJIGO4? Entirely possible I am confused about what the number means in the forum.
Well then, THAT certainly makes sense. Kinda funny that they specify feet in DJIGO but meters in the forum, but at least you have a reasonable explanation.
You are welcome :-) In the DJI GO App you choose the unit, In the forum it is probably set by the geographic location of the server ie, the unit in use in the Country...
The meter is one of the international standard units of measurement adopted by developed countries. With the USA being the only 'Western' nation not to adopt the standards.
Have you synced your flight records with the DJI servers? If you do not sync your flight records, there will be no distance listed. For some reason, your birds are listed. I thought your birds would not be listed to, but maybe all you have to do with the birds is activate them.
If you are syncing your flights, then check with DJI as to why it is not showing.
Aardvark Posted at 2017-7-24 14:30
Let's ask DJI to convert to the Smoot -or the Sheppey !
