Donnie *
Flight distance : 3636782 ft
Ioannou Posted at 2017-9-15 01:26
Mindy I am afraid that the problem with the CPU overloading has not gone.After nearly two months I fly today and on the 5th battery the problem appears again,the difference is that didnt appears from the 1st battery.Also I got another warning with battery error(only at the starting of the AC) with all 5 batteries and then disappears
Thank you
On your phone b e sure to turn off the Video function , so you cant record to the I phone, also be sure to enable "hardware decode" as well . You want to take as much load off the Go app device that you can . also eliminate the Cache.
This is not a GO app problem but a Go App device problem , It does not have enough Memory and or power as the Go app device sucks it up >
Get An I-pad pro (standard size) for flawless video etc.
donnie |
