Donnie *
Flight distance : 3636782 ft
Depending on the update of firmware version , the AC can lock up and stay in travel mode , the only way to unwind that is to rollback the Fw on the RC then update the AC first then reload the FW on the RC . This happened around update 1.8. on the AC if memory serves me correctly .
I have seen this at least 25 times .
It is just a good habit to always update the AC firs and sometimes critical .
donnie
Below is an exerpt from the PDF release notes, be sure to read these before every update. The release notes are on the same page as the FW updates over to the left of the page.
[size=14.000000pt]2016.04.07
- Firmware upgraded to v1.8.1.00
- DJI GO Android upgraded to v2.7.2
[size=13.000000pt]Major Updates
- Improved encryption to enhance security during transmission. Both the aircraft and the remote controller must be upgraded or else they will not link.
- Fixed the issue of landing gears lowering in midair on rare occasions.
- Improved stability for camera.
- Optimized gimbal parameters.
[size=13.000000pt]Notes
- Be sure to upgrade the aircraft before upgrading the remote controller, otherwise the aircraft may not able to exit Transport mode properly.
- [size=12.000000pt] [size=12.000000pt]Battery firmware is included in this All-in-One firmware update. Update all Intelligent Flight Batteries by using this firmware.
- [size=12.000000pt] [size=12.000000pt]Camera version v1.8.1.00 and aircraft version v1.8.1.00 should be displayed in DJI GO. The version will only display correctly in DJI GO after connecting to the Internet when upgrade is complete.
[size=12.000000pt]
[size=12.000000pt]donnie
