cameracollector
Flight distance : 807133 ft
Geebax Posted at 2017-8-1 17:29
I have viewed the clip you uploaded to Dropbox on my high-end editing computer and it is near to perfect. I say near, because a wheat field is almost as bad a subject as it is possible to choose to shoot with a camera that uses MPEG compression. In a wheat field there is so much fine detail that the MPEG encoder is working it's butt off trying to preserve as much detail as possible, but you are shooting 4K at 60 megabits per second, which is actually a fairly slow rate. With a P4P you could shoot the same scene at 100 Mb/s and it would be a bit better, but at 60 Mb/s that is about as good as you will get.
You might try viewing it using VLCPlayer (free download) as that may handle the replay better, but if you still cannot get an acceptable replay then unfortunately your computer is not up to the task. In summary, I don't seen any flicker at all.
Thanks for the reply - that helps explain it better.
Out of curiousity, what is your computer setup? After I bought my P4 I upgraded from my old Dell i7 (12GB ram, 1GB video card) to a machine with 16GB RAM, Intel Six Core i7 6800K (3.40 GHz) with a AMD Radeon RX 480 8 GB GDDR5 graphics card. I also added a 500GB Samsung SSD & moved the OS to it, and a 2TB WD black for extra storage.
This is the machine I have: https://www.newegg.ca/Product/Pr ... 01482409.1473221802
Even with all this I find the 4K footage taxing the system, VLC is pretty well unusable for the raw footage which is strange because it was the best player for my 1080-60 gopro footage on my older system. I can play the DJI files okay in media player, but if I'm trying to watch one while the others are are still being copied from the SD card forget it.
I figured with such a big step up in processor power and graphics card and another 4GB ram I'd be able to watch a file playing stutter free even while doing other things, which is clearly not the case. The VLC stuttering is a mystery too - perhaps I need to tune the system more, I was thinking of bumping the RAM up to 32 or 48GB, if that would be the best place to put the extra $$
