Cetacean
Flight distance : 2528264 ft
Aloha fansac5,
It looks like you are using the DJI Goggles with your P4 Pro. So, this is the Phantom without the built in screen? You had to install a HDMI module? There are different procedures depending on what product you have. If you are not using the Plus, your device will also be involved and will have resolution input qualities. Oh yeah, you are using an iPAD.
The important part of your installation is you have to refresh the current firmware for your Remote Controller. This is done through the Assistant 2 software on your computer. If you do this, the remote controller will now recognize that you have added new hardware to your remote controller and install the required software for it to work properly.
Generally, HDMI displays have to be on and active prior to any input means. Depending on what device you have, there is a page in the General Settings for the HD that asks you HDMI questions. Be sure to address them before coming back to the Forum.
Hope this helps!
Aloha and Drone On! |
