Aardvark
Flight distance : 384432 ft
Collielaw Posted at 2017-7-30 04:43
Using on samsung galaxy s7 edge or samsung tab 10 which it has always worked perfectly on, the app version is 3.1.8, the version is 1.11.20 and the remote controller is on 1.9.2?
You could try an RC reset and relink to aircraft, that may or may not help:-
* Turn on the controller, the aircraft should be off.
* Press C1, C2, and shutter (top right button nearest antenna) on the controller and hold for about 2 seconds or so until it beeps (D-DDD), then turn the controller off.
* Turn on both the aircraft and the controller and link the remote if needed.
This can be done manually (without using DJI Go):-
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button (top left button) on the controller, then the controller will beep 'D-DD'.
*Let go all fingers, then press the wheel on the right side of the controller (It's a 'click wheel', similar to a mouse wheel) and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon |
