Aardvark
Flight distance : 384432 ft
fans61699a75 Posted at 2017-7-30 08:52
Hi aardvark
On the dji website at product support aircraft faq , it mentionned that you still can do a quick vision calibration via dji go app. Is this old info and is that tool definately gone in dji go app?
"11. How do I calibrate the Phantom 4 Pro's Forward, Backward, and Downward Vision Systems?
The Forward, Backward, and Downward Vision Systems can be calibrated with DJI Assistant 2 and DJI GO. If there is an error with the Forward, Backward, or Downward Vision System, a prompt stating that auto calibration for the Vision System is required will pop up in the DJI GO app. Follow the instructions in the DJI GO app to calibrate. For the best results, we recommend calibrating the Forward, Backward, and Downward Vision Systems with DJI Assistant 2. If you don’t have a computer at hand, calibrate them with DJI GO."
This one :-)
Page 28 of P4Pro manual:-
In DJI Go 4,Tap 'Aircraft Status' then 'Calibrate Vision Sensors' to start quick calibration.
