spark range
12Next >
3761 40 2017-7-30
bener
Flight distance : 24012 ft
Cyprus
I live ib Cyprus and i am happily flying my spark. I had my more combo for nearly 2 months. As I read the flying range of it I wanted to try how far I can go. Unfortunately I cant fly higher than 90 m. (it is set to 500m) and I cant fly more than 300 m. I can see the Spark there is no obstacle in between but still I have my RC connection cut and it starts to return home. How can I correct this issue ?
2017-7-30
ImHereToCrash
Flight distance : 5381368 ft
first thing i have to ask, are you using the controller ?  do you use an OTG cable between phone/tablet  and controller?  if not that can cause interference having the phone/tablet chatting on the same singal..
second of all, you must have gotten your hands on the european model as well which has a seriously limited wifi output.. quarter of a watt vs most of the rest of the world gets half watt of power output..you should be able to get 300-400 meters assuming little interference.. and you are using controller with a cable connected to the phone and phone has its wifi disabled..
2017-7-30
Zirconn
Flight distance : 242920 ft
Romania
310m meters is best i've got, in a field near some woods. 2.4GHz, OTG cable, phone in airplane mode, good line of sight. One WIFI network in the area, low signal.
CE regulations sux.
2017-7-30
Lucas775
Flight distance : 50642090 ft
some guy on youtube got over 10,000ft.
2017-7-30
ImHereToCrash
Lucas775 Posted at 2017-7-30 14:36
link?  that's almost 2 miles!
2017-7-30
Lucas775
ImHereToCrash Posted at 2017-7-30 14:45
https://www.youtube.com/channel/UCMaYt8kdIR5U3ZwWiZJ6WnA
2017-7-30
fans72e8b49d
Flight distance : 5188369 ft
I got over two miles too. 10500 feet
2017-7-30
Lucas775
fans72e8b49d Posted at 2017-7-30 15:59
Awesome! I guess it's not that hard specially if you are in a wide open place.
2017-7-30
bener
Cyprus
ImHereToCrash Posted at 2017-7-30 11:55
i am connecting with RC wifi.NO Otg cable.May be mine is European model.Isnt there a way to to increase the power output?
2017-7-30
ImHereToCrash
bener Posted at 2017-7-30 21:38
unfortunately currently no way to increase the output(without hacking/modding)..  try using a OTG cable and turning wifi off on your phone.. should help..
2017-7-30
bener
Cyprus
ImHereToCrash Posted at 2017-7-30 21:50
OK Thanks. I wıll try the OTG cable.
2017-7-30
LeChuck71
Flight distance : 68786 ft
Please don't mix FCC / EC regulations
2017-7-30
eylneb
Flight distance : 122477 ft
Malaysia
Flew from 1 island to another.. 1.7KM away
RC Wifi to phone, not using OTG
2017-7-30
bener
Cyprus
eylneb Posted at 2017-7-30 23:55
But its not in Europe yes? Our sparks in Europe comes with little RC power
2017-7-31
eylneb
Malaysia
bener Posted at 2017-7-31 06:57
right not in europe...
unfortunately for europe.. there is a regulation about power transmission.. so u dont get 2km..
2017-7-31
DJI-Mark
Always suggested to fly safely.  You always need to make sure you are logged into the Go 4 App before beginning otherwise you may be limited on how high you can fly.
2017-7-31
DJI-Mark
2017-7-31
paulhummerman
Flight distance : 114915 ft
I'm in US, using otg, phone on airplane mode, LOS, but is disconnecting at 800 feet. So far reconnects without initiating rth. the spark is already very difficult to see at that distance.
2017-7-31
paulhummerman
I'm in US, using otg, phone on airplane mode, LOS, but is disconnecting at 800 feet. So far reconnects quickly (eg if I move a bit closer) without initiating rth. the spark is already very difficult to see at that distance, and I need the video feed  to bring it back.
2017-7-31
roberteb
Flight distance : 131417 ft
See my post  1km CE   switch to 2.4Ghz
https://forum.dji.com/thread-107091-1-1.html
2017-7-31
fans72e8b49d
Over 10,000 feet
2017-7-31
Lucas775
LeChuck71 Posted at 2017-7-30 23:46
Please explain.
2017-7-31
LeChuck71
One post is from cyprus and I guess they use EC regulations according to the signal strength. The video you mentioned is from a guy in the US and they use FCC signal strength. You can't compare them regarding range and it confuse people that didn't read about this and maybe they claim that their range is not "wide" enough.
Guess Canada use FCC as well ;)
2017-7-31
bener
Cyprus
So when we see an advertise of a drone telling about the max. range we should know the exceptions then. I was thinking to buy an Inspire 2 knowing that it has 7 km. distance range. Now I know it is useless to pay more than 3000 USD. if I would not be able to go more than 300 meters. Who would pay a drone 3000 USD. which would fly this short. ?
2017-7-31
eylneb
Malaysia
Each country has regulation in terms of the power of the transmission. The higher the power the further spark can go.. FCC is US reguratory body CE is eurpoe.
http://www.batteryspace.com/ul-ce-emc-fcc-and-csa.aspx
spark's power transmission for remote controller
2.4 GHz
FCC: ≤26 dBm; CE: ≤18 dBm; SRCC: ≤18 dBm; MIC: ≤18 dBm
5.8 GHz
FCC: ≤28 dBm; CE: ≤14 dBm; SRCC: ≤26 dBm; MIC: -
which translate to about
        2.412 - 2.462 GHz (unobstructed, free of interference)
FCC: 1.2 mi (2 km); CE: 0.3 mi (500 m)
SRRC: 0.3 mi (500 m); MIC: 0.3 mi (500 m)
5.745 - 5.825 GHz (unobstructed, free of interference)
FCC: 1.2 mi (2 km); CE: 0.18 mi (300 m)
SRRC: 0.7 mi (1.2 km); MIC: -
2017-7-31
eylneb
Malaysia
bener Posted at 2017-7-31 23:01
yes, you should know which standards your country recognize..
Based on inspire 2 specs site..
i guess there are some criterias that dictates the transmission's power (EIRP)
2.4 GHz:
FCC: 4.3 miles (7 km);
CE: 2.2 miles (3.5 km);
SRRC: 2.5 miles (4 km);
MIC: 2.5 miles (4 km);
5.8 GHz:
CE: 1.2 miles (2 km);
SRRC: 3.1 miles (5 km);
MIC: - ;
2017-7-31
Koppo
Flight distance : 191726 ft
Croatia
I tried the max distance yesterday. I came to 1,1km.
2017-7-31
eylneb
Malaysia
guess turkey is under CE...
2017-7-31
bener
Cyprus
HMMM. Then I think for a solution. Instead of buying the drone through internet its better to go to a country where it is FCC rules and buy the drone there and bring it back to my country.
2017-8-1
bener
Cyprus
Koppo Posted at 2017-7-31 23:24
is your country in FCC rules?
2017-8-1
bener
Cyprus
eylneb Posted at 2017-7-31 07:31
But ı have  a Phantom 3 pro and it flies more than 1 km. Still in Europe.
2017-8-1
Lian82
Flight distance : 796775 ft
In Europe 1.5km not problem...if u are in openland no interference...
2017-8-1
Arcicorsa
Flight distance : 235892 ft
Czechia
bener Posted at 2017-8-1 02:38
It is nonsense !!!! All Sparks have identical HW for FCC and EU !!! Output power is automatically switched based on GPS position. I live in EU and my max flight is 1.5Km, look at flight record. Spark is not have any mod!!
https://healthydrones.com/main?f ... 3b1bc5c26897e3cda8a
2017-8-1
eylneb
Malaysia
Arcicorsa Posted at 2017-8-1 04:18
yes you are right... : )
2017-8-1
eylneb
Malaysia
Lian82 Posted at 2017-8-1 02:57
i guess based on conditions yes it is possible...
2017-8-1
bener
Cyprus
How comes.I live in EU too (Cyprus) And mine can't go more than 300 meters. Why is that?
2017-8-1
Arcicorsa
Czechia
bener Posted at 2017-8-1 07:53
Hello, I flight with OTG and AC/RC link is on 2.4Ghz. Very important is RC antenna aiming! You must aiming flat side of antenna to drone (not top of antenna).
2017-8-1
paulhummerman
paulhummerman Posted at 2017-7-31 11:28
I realized 2 things (from reading this forum). First, my 800 feet disconnect yesterday  was not strictly LOS - I was flying over a forest on undulating ground, and trying to fly close to the canopy top (more interesting video). So at 800 feet there were some tree-tops between me and ac, which compromised the wifi and led to the brief loss of connection. Today i flew  higher and did not lose connection even at 1200 feet. Also, i used pro guards which made the spark more visible.
2017-8-1
bener
Cyprus
Arcicorsa Posted at 2017-8-1 08:50
Yes I know that. I have a Phantom3 pro as well. I learned to keep antenna perpendicular to drone. With PP 3 I go good range no prob.
2017-8-2
bener
Cyprus
bener Posted at 2017-8-1 02:42
But I am not using OTG cable. I connects wireless. Why does it make difference? My connection to RC is ok all the time.
2017-8-2
12Next >
