KEDDK
Flight distance : 1133038 ft
Denmark
Well here's my story
P4P+ bought mid June, took 1½ week to get anywhere due to requrement of access to a WIFI connection.
Finally i got access to WIFI, took a lot of attempts to get an account created from the remote in order to register the thing but it managed to get thrugh at last. Now at was presented of some FW mismatch message that was solved by simply letting it update by itself.
AC restarted, and the famous late June "Update required, you can always downgrade if you dislike bla bla bla" message popped up. i like to be updated and didn't know how old the FW was when i bought the thing, so upgraded without any trouble.
From here it was flying and recording wiht no issues at all, only thing was i could not download local maps but had the choise to update maps for china?
After around 2 and a half week flying and recording with pleasure i noticed a thread in here, where a DJI supporter advised to reset the controller in order to fix the missing map download issue, did that and from that point almost all reported issues hit me and has not been solved yet.
Sticks very touchy/sensitive.
AC unstable, yoyo like slowly wobling up and down, slowly rotating after letting go of the sticks.
Sometimes loosing connection within 300 meters distance at 30m height at clear sight over cultivated fields out in the country, other times no problems a around 1km + beside the video feed might become unstable/flickering.
When shooting video and rotating in place it clearly shows some shaking in the movie like the gimbal does not follow/hold track with the AC and moving along in small steps.
Warning of high wind even with the flag on my pole hanging without any movement at all (no or very little wind)
Sensor system has become very sensitive too, the thing is beeping like mad from take of until i get around 6-8 meters up. and again when trying to land it goes mad in beeping, sometimes figting against going the last distance to the plastic box i use as platform for tanking off/landing.
I have noticed that sometimes it think it is upto 4 meters higher when landing the same place it took off from, sometimes half a meter below ground, even it always get plenty of time to warm up before taking off, have itself record the homepoint etc. while i check everything the last time including the record settings.
a few times i has noticed it make a short flip back or forwards at the time it set down for landing, like it almost try to flip over, even landings always are very gentle due to the fighting back against going down.
From the intelligent modes i have only tried the Follow terrain and tripod mode, i guess the terrain mode does as it should but wish it could also decend hight when following the road downhill. The tripod mode was absolutely unusable as the thing was drifting from side to side and a little back and forward, in other words very unstable also in tripod mode and stcks still very touchy/AC agressive.
So what it would like to report is that from my POV. it was not the firmware upgrade in itself that startet the trouble but the factory reset of the remote some weeks after the upgrade.
I has tryed to refresh FW on both RC and AC, calibrated sticks and compas but nothing has helped at all, seem more like it is getting worse everytime i try out something. :-(
I am getting a anying popup where i has to confirm some warning zones even i am far from any where i flight the most, those popup after taking off and sometimes i only notice them when i need to change something or control the camera exposure etc. as i have no problems flying around even the warning has pop up on the display.
Then theres the HDMI without overlay issue and possibly things i have not found out yet, really hoping DJI would supply a tested stable firmware soon or at least put back the promised downgrade possibillity.
Like i have seen other asking i has considered looking out for hacked/3rd party firmware but really it can't be that we should get that way in order to get a stable drone! |
