gkordowski
Flight distance : 798360 ft
Jersey
Just to clarify re Gimbal cover - directly from DJI:
https://store.dji.com/guides/10- ... ic-pro-pilots-make/
Point 3.
Let’s go over some Mavic terminology. A DJI Mavic has 2 pieces of plastic protecting its gimbal. One is called the Gimbal Cover. This is the astronaut helmet bubble that protects your gimbal and camera lens from being damaged. The other is the Gimbal Clamp, which locks the gimbal in place and keeps it from moving around during transport.
Leaving the Gimbal Cover on during flight isn’t necessarily a mistake, depending on what you want to do. Leaving the cover on during flight will make sure your Mavic’s gimbal camera is protected from the elements, such as dust or water. It will give you an extra level of protection if you’re concerned about something hitting it. So if you just plan on exploring your area or zooming around (safely) in Sport mode, you can leave it on. It won’t affect gimbal or flight performance.
But, if you want the best image quality, possible, it’s a good idea to remove the cover. For example, leaving the Gimbal Cover on makes it more likely that you’ll get lens flare, and your shots may not look clean if the cover is dirty.
So there’s a trade-off: leave the cover on for extra protection, or take it off for the best image quality possible. |
