Spark "Battery Signal Error"
11457 23 2017-7-31
KRONOS
Singapore
Hi
After updating the latest firmware on my spark I was unable to fly the drone, it keeps prompting me of Battery Signal Error and battery display remains as NA
Does anyone have the same issue? Any solution?
Cheers
2017-7-31
DJI Diana
Flight distance : 2408 ft
Have you tried to re-upgrade it via DJI Assistant 2?
2017-7-31
ImHereToCrash
Flight distance : 5381368 ft
interesting issue...  im assuming the battery is on the wrong/mismatched firmware.
however if it isn't on mismatched firmware then that just weird
2017-8-1
eylneb
Flight distance : 122477 ft
Malaysia
ImHereToCrash Posted at 2017-8-1 00:34
apparently mismatched firmware's error isnt like that..
yes if you have 10 batteries, you need to "install new firmware on all 10 batteries"
2017-8-1
KRONOS
Singapore
DJI Diana Posted at 2017-7-31 23:56
Oh, I have not done that. I will try and revert with outcome
2017-8-1
KRONOS
Singapore
Hi
I have tried to upgrade via DJI Assistant 2 and it says upgrade fails after a few attempts
2017-8-1
DJI Diana
KRONOS Posted at 2017-8-1 01:27
Hi
Try to downgrade it to the previous firmware, could you please provide me with the serial numbers of the drone and battery?
2017-8-1
KRONOS
Singapore
DJI Diana Posted at 2017-8-1 01:46
I had tried to downgrade to the other 2 lower version and it says upgrade fail as well. I have also uploaded the error log.
Drone: 0ASDE540A100KP
Battery:0C0AE54031011L
2017-8-1
DJI Diana
KRONOS Posted at 2017-8-1 02:04
What error message you've got in the DJI assistant 2?  Have you tried the other batteries?
2017-8-1
KRONOS
Singapore
DJI Diana Posted at 2017-8-1 03:04
The Error message is 0x02a303. Yes I tried both batteries I have and its the same
2017-8-1
DJI Diana
KRONOS Posted at 2017-8-1 03:06
Could you please find the upgrade log for analysis? You can find the log on your computer,  Go to C:/Users/XXXXXXXX/AppData/Romaing/DJI Assistant 2/upgrade_log,  export the Log file to the local, then upload it to the Dropbox, provide me with the link. Thank you in advance!
2017-8-3
Draisabin
Indonesia
Hi, I have the exact same issue. I bought the fly more combo in red a few days ago and have the issue with both batteries. I updated the drone, controller and batteries through the dji 4 iOS app on my iPhone 7. Then in the evening the error came "battery signal error". I cant factory reset on the assistant 2 on win10 pc, and if I want to update the firmware with one battery it gets stuck at 97% and with the other it goes to 57%, then back to 54% and back up to 57%. Once it reaches 57%, it stops for a while and then tells me the update failed due to error code 0x02a303. If I try to refresh firmware using the dji go 4 app on my iPhone 7 the wifi disconnects at 99% and when I reconnect to wifi the app crashes. I open it again and then it says updating at 97% as if I'm updating the firmware, and then it says failed to update. Help!!
2017-10-15
fans4525f35f
Malaysia
Draisabin Posted at 2017-10-15 03:25
Same here, any updates?
2017-11-25
djiuser_t2Jsstz
Flight distance : 4705 ft
Hi, same issue with my one, this morning i did upgrade for APP, in afternoon i couldn't fly my drone, Spark could not hold one position, was moving around, no signal for battery life, no blinking lights on battery during fly, no video transmission on WI-FI, with USB cable (phone-remote control)  i was able to see video, but it doesn't shows how many satellites signal Spark got and no battery life signal.
2017-11-25
fans48119fcf
Flight distance : 74101 ft
Philippines
hmm I have exactly the same issue but on a mavic pro. both of batteries appear N/A after updating to the newest firmware 2 days ago. did you find the solution? the customer service just asked to restore to factory default and refresh...but kept on getting a update error
2017-12-2
Jones_Media
Flight distance : 78714 ft
Guam
I too had the same problem today , but it happened within 2 minutes of flight, but i was still able to fly . The battery error message continue to display at the top where the min left bar is at.
2017-12-2
djiuser_nI6IIGw
Czechia
Same problem here on Spark, 2 batteries N/A status from yesterday! WTF?
2017-12-2
djiuser_uc8WVdl
Indonesia
Same problem too, in my Spark,
I have 2 Batt, and it's Status still N/A (and GPS too)  after I Refresh to both 2 batt (DJI Asst 2)
2017-12-10
djiuser_uc8WVdl
Indonesia
PROBLEM SOLVED
Unplug OTG, use Wireless to RC, Spark's Info will shows up.
I hope DJI can updates Their APPs to support OTG
2017-12-10
WILCAMP
Brazil
Hello everyone
I still have the same problem of "battery signal error".
I have tested other batteries and the problem persists. What's worse is that when I put my batteries in a friend's SPARK they work normally.
I can not update the firmware via DJI ASSISTANT 2, it always gives an error at the end of the process.
Please help me.
2018-4-10
Adarp
Indonesia
hi everyone
I have the same issue with battery signal error. i've try 2 battery and still same error.
even i try the batteries to my friend's spark, it's works normally.
anyone has solve this problem?
thanks
2018-10-17
newbf1A
Japan
I have the same problem too. Why Dji doesn't reply?
2018-12-15
Etereokiller
Chile
connect the dji spark trougth usb cable to the computer, connect the pc by Rj45 Lan cable, disconnect de wirelless of your cpc, open the DJI Assistant 2 and update. thats works fine for my
2019-7-23
fans6f4c4b0e
Flight distance : 157766 ft
South Africa
Hi.
Iam suffering same battery connection issue,
I have 8 batteries, a few days ago 1battery stopped working,then a second and now 4 are dead, I think old.. but unsure as my friends spark same age has 4 batteries all still working.
4 dead batteries and 4 I still use, today after connecting to fly all remaining 4 are showing connection error and cannot take off..
Iam currently travelling and don't have a lap top or PC with me...can you advise
2021-12-1
