LUTs not loading in PPCC2015
693 3 2017-8-1
Wolfie
I tried to load the LUTs from DJI into PP 2015.  I put them in folders.  Don't show up.  Tried to browse to them using custom and PP won't load the file.  Other LUTs (from Ground Central for example) load and properly process.  The ones in the ZIP from DJI don't.  Should I just forget them and use GC's?
Also is there any lens correction profiles for PP for the X5R and the stock 15mm?  In Lightroom it reads the meta and auto corrects.  Not seeing that in PP.
2017-8-1
I have feedback this issue to our engineers for analysis. I will come back to you once I hear from them. Thanks for your patience.
2017-8-2
DJI_camera
As to the LUT issue, it is compliant to Resolve format and may not be usable in Premiere.
However, you can convert it to Premiere format by yourself.
Open the LUT file with a text editor and delete the line starting with
"LUT_3D_INPUT_RANGE 0.0000000000 1.0000000000"
and save it. After this modification you should be able to import it to Premiere.
2017-8-4
Wolfie, please refer to the suggestion posted on 3# by our R&D engineers, hope it works.
2017-8-5
