Ronin MX not centred
113 6 2017-8-2 04:38:57
XFkrhT6n7ZzK
Beginner
Flight distance : 35482
Hi all,
Since I've seen a number of topics about this issue, I still not havent found a solution of this problem.
My Ronin MX is slightly out of center on the pan axis.
With the trim set to 10 (or -10, I cant remember), it is still not centred properly.
I have made sure all my firmware and software is up to date, but my Ronin MX keeps getting aligned a bit off center.
Does anybody know how to fix this issue and how to re-align all axis to center position?
Kind regards,
Dennis
2017-8-2 04:38:57
TimekeeperFilms
Beginner
Hey Dennis!
Not sure if this will help, but do you have the DJI assistant app for either your smartphone or computer? If not, I'd highly recommend getting it because it will help with this issue as well as many others and is vital to make sure your Ronin is functioning correctly. I have a Ronin-M, but I don't think the app is different between M and MX. On the phone version of the app, there will be an option under the "more" tab called "calibrate center". When you press that, the app should prompt you to use your remote controller to center the Ronin on its pan axis. Once you've done that, confirm. The app may then prompt you to restart the system for the changes to take effect. Hope this helps!
-Andrew
2017-8-4 21:49:08
djiuser_YRKC2hO
Beginner
Hi Andrew,
I have the app, but I have never seen that option.
I just checked, but the only calibrate option I have is 'Calibrate System', using this option will calibrate the device with the center still being off..
2017-8-6 12:25:35
DJI Natalia
Japan
Please enable Pan Smooth Track, set the Deadband to 0 and Speed to 100 after you turn the unit on to make it centered.
Besides, you can try to calibrate system.
2017-8-9 01:20:53
djiuser_YRKC2hO
Beginner
Thank you Natalia,
But the Ronin MX will stay off center, both before and after calibration.
Also the settings you suggested (I have them on as default) do not help..
2017-8-9 06:51:27
DJI Natalia
Japan
djiuser_YRKC2hO Posted at 2017-8-9 06:51
Thank you Natalia,
In that case, please make sure it is in Smooth Track mode, then upload a screenshot for "Live data" so we can check the value.
It would be best if you can upload a small video showing the situation you described that it's off center. Thank you!
2017-8-14 03:36:14
djiuser_YRKC2hO
Beginner
I'll do that!
1 day ago
Close
DJI RecommendsPrevious /1 Next
