Donnie *
Flight distance : 3636782 ft
Ok, here is a link below I wrote on instructions on how to update the RC via a thumb drive . ONLY DO THIS TO GET TO VERSION 1.3 ON THE RC then update via wi fi connection . You might be able to get to verison 1.6 this way but you will after that nned to update via wi fi as 1.6 is the laston that will work , try doing it vai wi fi and the go app after 1.3 please.
http://forum.dji.com/thread-47577-1-1.html
Only update the RC to version 1.3 and then update the RC to the latest version via the wi fi connection . Do any updating to the RC only AFTER you get the AC loaded FIRST. ( past firmware 1.3, befroe that it does not matter )
Make sure you read my tips page !!!TIPS FOR UPLOADING FIRMWARE - SD card updating and RC Transmitter
So I would like you to get to both 1.3 on the RC and the AC and then update the AC first to the latest version and then do the RC . If you get the RC updated before the AC in some cases it can get the (AC ) systems stuck in travel mode .This will only happen after you get to version 1.3 on the AC and the RC.
What happens when you load the SD card with Only the BIN file to the AC ? do you get any sound at all ? Are you using a PC or MAC , are you formatting the SD card before loading the Firmware and making sure only the BIN file is on the update ????
Ideally you want to use a PC for formatting and loading the Firmware to the SD card , You can do it via a MAC but if you do be sure to format the SD card on the aircraft . You can do this from the tools section on the go app, go to the tools section on the camera settings ( center of go app on the far right , main screen ) . This way you are sure to get a proper format . Do you already know how to do that ?
Did you ever update the AC at all ? EVER ( I am assuming that the AC is just like the RC and NEVER been updated ) and does the system still work ? Can you see live video from the camera to the go app device ? if you never updated the system should still work .
regarding your questions : Yes, up to version 1.3 the update is done via a thumb drive and should update , once you get to 1.3 updating is done( on the RC only ) via the Go app and a wi fi connection . The AC is ALWAYS updated via an SD card in the camera .
NO there is No reset for the AC at all .
Below is a Pic of what the file will look like when you drag and drop it to the thumb drive , Make sure none of the other PDF files are with it ONLY the bin file .
below is bin file 1.02.01.06 , this is what it should look like right before you load it to a thumb dirve or SD card for the first update .
Let me know
donnie
