VoDoXuS
Flight distance : 88619 ft
Singapore
StianGel Posted at 2017-8-4 04:36
You can take the card from the drone/osmo and review the high res files.
If you have a suitable USB memory stick you can transfer the files to that. That way you don't have to use multiple SD cards. (USB memory stick's are way cheaper then SD cards)
Hey, Just checking,
Not like I have a choice of editors, but does the DJI Go4 editor able to edit the full res videos from the sd card? I realised on mine, it only works on the files saved in lower res on the CS itself, rather than the full res ones from the drone. |
