Multiple RC disconnections after FW upgrade
802 3 2017-8-3
monch0te
Flight distance : 105787 ft
Hi there!
Yesterday was the first time flying my Spark after July's FW update. I hadn't had any problems this far apart from the Bluetooth interferences which were solved by simply turning it off on the iPhone.
I went to my usual flying spot and after getting the GPS lock and taking off I noticed the RC and the Spark were communicating via 5.8Ghz instead of 2.4 as before. Everything seemed fine until after a couple of minutes and when the Spark was 100m away from me I suddenly lost connection to the aircraft and it automatically initiated a RTH manouver.
On its way back to me I regained connection and lost it several times. At no point did I get a low signal or interference warning. Luckily I managed to get it back with no issue but now I'm concerned to fly it, to be honest.
Here's the flight log: http://healthydrones.com/main?fl ... ENERALNotifications
I tried to report the .DAT file from DJI Assistant 2 but it would complain about the phone number format when submitting the form and wouldn't let me.
Any suggestions would me much appreciated!
2017-8-3
monch0te
Flight Data: https://www.dropbox.com/s/kqpxv6 ... 2_23-20-13.DAT?dl=0
Black Box: https://www.dropbox.com/s/e0erau56u2mni1g/BlackBox.zip?dl=0
Controller Log: https://www.dropbox.com/s/759v4i ... 1-23-06%5D.txt?dl=0
2017-8-3
DJI Natalia
Flight distance : 318 ft
monch0te Posted at 2017-8-3 05:32
Flight Data: https://www.dropbox.com/s/kqpxv6p51igpou0/DJI_ASSISTANT_EXPORT_FILE_2017-08-02_23-20-13.DAT?dl=0
Controller Log: https://www.dropbox.com/s/759v4iyzqj3dxmd/DJIFlightRecord_2017-08-02_%5B21-23-06%5D.txt?dl=0
Thank you very much, I have forwarded the data files to engineers for further analysis, will get back to you  when we get the result.
Appreciate your support!
2017-8-3
Beretheon
Flight distance : 101027 ft
Poland
any updates in this case? I have similar problem - yesterday dissconection at 160m, out of town, no powerlines etc. Spark was 60m attitude and clear i line of sight. Im thinking about posting a support ticket.
2017-8-16
