Spark flyaways - some thoughts
1157 10 2017-8-3
Spookymike
I´ve seen some reports and Youtube Videos like many of you i think, which say that the Spark sometimes get some sort of flyaway.
Mainly when a disconnect to the remote/phone happens, where the drone should come back to the homepoint.
Normaly after takeoff a message appears "Homepoint has been updated..."
I experienced lately that there was no such message after takeoff. Could it be that spark has the last known takeoff point internally
saved, and when the new homepoint got not updated at the actual flight, it just thinks in case of a "Failsafe" it want´s to reach this
old Homepoint?
And this appears to be known as the bad "Flyaway"?
2017-8-3
Thor1
Flight distance : 196837 ft
this was a theory someone suggested on another thread and they have never came to a conclusion but it is definitely possible. at the same time while the drone is in RTH mode you are still supposed to be able to control it or cancel RTH so maybe its a combination of what you suggested and an RC link failure?
2017-8-3
Monochrome
Flight distance : 12710 ft
Poland
Usually it is beacuse of compass error. Spark know where the home point is but because of that error don't know in which direction or rather it thinks that it is in different direction.
2017-8-3
Adriano Araujo
Flight distance : 731565 ft
Brazil
Don´t understand why a compass problem would interfere in the navigational system.
It is very simple to get direction (north, south, etc.) from GPS alone (as long as you are in movement) – Two point calculations. There is a lot of smartphones with no compass that do that.
It is VERY simple to find homepoint without compass.
2017-8-3
Monochrome
Poland
Adriano Araujo Posted at 2017-8-3 07:46
Every modern smartphone have compass/gyro. Mine if not calibrated think very often that i'm heading in different direction. The same can happen to Spark. No device that relly on gps only when it comes to real time orientation. Especially not when it moves fast. Calculation based solely on GPS is just to slow and not precise enough. I'm not the expert byt that's just my 2c.
2017-8-3
Resqman911
Flight distance : 28045 ft
If you take off without the app showing ( and telling ) you that the home point has been updated, and you dont check it on the map ( which it also tells you ) then you are rolling the dice. There are reasons why you may not be getting this message, my guess is you are turning the spark on and flying before it has aquired the proper number of satelites to set your home point.
My advice top you would be not to fly your spark until you figure out why your homepoint is not being set.
2017-8-3
hallmark007
Flight distance : 9827923 ft
If homepoint is not recorded land and start again, you should always make sure your homepoint is recorded..(HOMEPOINT RECORDED PLEASE CHECK IT ON THE MAP) so first check your map , I haven't seen any proof that aircraft disconnected and just flew away, I have had AC disconnected and my spark just RTH .
2017-8-3
hallmark007
Why would a compass error disable GPS?
Orientation (compass data) and position (GPS data) are different but related.
When the Spark is moving and getting position information from the GPS that tells the Spark that it is travelling in a different direction from what it's getting from compass data, The Sparks programming can't work with the data conflict.
The solution is to drop data from one source and since the Spark can't fly without a compass but can without GPS, it's the GPS data that gets dropped.
2017-8-3
STech - Hathder
Flight distance : 459094 ft
Brazil
Remember, if you use wifi (phone) to controll spark, theres no map on screen! Theres no way to check drone direction before flight ( only map position on lost my drone function).
2017-8-3
hallmark007
STech - Hathder Posted at 2017-8-3 09:46
If you use phone you are within 80 metres, you should know direction and should be easily able to fly your AC to safe place.
If you are flying behind trees buildings then you have a problem, but I consider this user fault.
2017-8-3
STech - Hathder
Brazil
hallmark007 Posted at 2017-8-3 09:48
If you use Phone WIFI to control Sparkl and are flying at 80m distance, every problem you have and spark start to flyaway, YOU LOSE CONNECTION. Spark direct wifi phone connection starts to warning low signal at about 10m distance and eventually loses signal, its "normal".
Other problem.. wifi phone controlled spark doesnt have SPORT mode, so its limited do 10km-h speed, if atti mode doesnt change that, every 10KM-H WIND will blow spark away, even if the pilot pulls full throttle in wind direction (if return means go in wind direction).
2017-8-3
