Elettrone78
Flight distance : 2840512 ft
OK this is what I found out:
- The original 120fps video on Windows Media Player or VLC stutters even on a Core i7@3,4Ghz but not on Plex video suite. Plex will playback the video smoothly even on a crappy Pentium client(tested).
- I reset Handbrake video encoder settings to handle automatically h264 profiles and configuration, I only set the quality output and the trascoding accuracy(speed) and magically all the transcoded videos run smoothly on any player.
My conclusions:
- The Inspire 2 has no defect or issues whatsoever
- For some reason that goes beyond my knowledge the default windows player doesn't like the original footage but the fact that Plex works like a charm makes me think that the issue is not on the computational side, even a low end pc will run the files smoothly.
- It looks like I had some "weird" settings in Handbrake even tho i transcoded files coming from my Canon EOS 1DxII with no issues of the sort, resetting them fixed the thing.
- 25/30fps is not enough to perform a smooth panning that runs equal or more than one full screen frame in less than 7 seconds.
Now if I really were to complain on something I could argue that there's a some aliasing on straight lines in the indoor video.
I hope that my experience helps someone else, thanks for the participation.
