Spark remote - not charging??
1284 4 2017-8-3
Eye in the Sky
Flight distance : 25046 ft
Has anyone had an issue with the Spark remote not charging?  Not sure if the remote is bad or the Pins got screwed up somehow?  Under refresh - something that I could send back?  Amd how long turn-around time..
Thanks !!
2017-8-3
DJI Diana
Flight distance : 2408 ft
Could you please provide more details about this issue? A short video about the issue will be highly appreciated.
2017-8-3
Sharkey
Mine charge in full the first time. Used it completly and never charged a 2nd time. I called support and they had no answer but to replace it with another one.....
2017-8-4
fans46160df4
have the same problem using the original cable & short aftermarket tried different chargers as well
appear to me that the receiver plug is misformed not allowing the cable to connect correctly.
what is my next move return to seller , DJI  a need retailer ??
Cheers
2018-1-23
Gunship9
fans46160df4 Posted at 2018-1-23 16:21
Use a magnifying lens and good lights to look at the receptacle.  It is upside down with an orientation tab on the bottom (maybe top as I can't remember exactly).  Cable only goes in one way.  It is not like a lightning cable or the fancy new USB-C.
2018-1-23
