Alternative Resolution for Gimbal auto calibration stuck at 50%
1845 9 2017-8-5
drone.archaryaa
Flight distance : 5961270 ft
India
Hello All,
I have been facing issue on my Phantom 4 pro with calibrating the gimbal. It used to get stuck at 50% with loud noise.
Apparently I was waiting for beta firmware in which DJI claims to fix the issue however I didn't get any beta firmware.
While playing around the settings I found that if you disable mechanical shutter setting in camera settings and then calibrate gimbal it get calibrated successfully without any trouble.
2017-8-5
DJI Susan
Could you PM me your DJI account? I would like to submit the request of permission to Beta firmware.
2017-8-7
drone.archaryaa
India
DJI Susan Posted at 2017-8-7 02:25
I have PMed you the same
2017-8-10
DJI Susan
Received with thanks! Please login your DJI account and refresh the firmware via DJI Assistant 2.
2017-8-13
Metron
DJI Susan Posted at 2017-8-13 23:39
Hi,
Should this issue be resolved by now ?
I again experienced it today, all the firmware is latest.
Disabling Mechanical shutter worked as work-around,
so the question is if it is ok to calibrate Gimbal with mechanical shutter being disabled?
thanks
2017-11-8
Humadrone
Flight distance : 1049304 ft
I got a ph4pro + , and it get stuck almost when disable mechanical shutter.
I cannot calibrate gimbal.
2017-11-9
DJI Susan
Humadrone Posted at 2017-11-9 01:14
I received your message in PM as well, thanks! The beta firmware is available in your account now, please try again.
2017-11-10
DJI Susan
Metron Posted at 2017-11-8 11:36
Hi,
Metron, I would recommend you to try the beta as well to solve it directly. PM me your DJI Account if you'd like to have a try.
2017-11-10
droningaroundth
Flight distance : 7344777 ft
Switzerland
I constantly get stuck at 50%. Trying to see if my gimbal stops vibrating... I had already sent my drone to Holland once due to vibrating gimbal and now it stated again!
Any help on how to move from 50%?
2017-11-20
DJI Diana
Flight distance : 2408 ft
droningaroundth Posted at 2017-11-20 12:28
Just to make sure I am on the same page, are you referring to a Phantom 4 pro? If yes, please provide me with your DJI account email, I'll add the beta to your account.
2017-11-21
