Geebax
Cetacean Posted at 2017-8-5 19:07
Aloha giuseppe,
Yes, the 128 GB micro SD card is the current limit of DJI video technology (used to be 64 GB). There are two ways to format the SD card, One is the Pre-Flight Check-List and the other is way on the bottom of the Camera Settings page on the desktop. So, format it with your MacBook and then format it again using either of those two methods. One of for the basic format and the other is for the DJI format for DJI videos (and photos).
You can actually skip the process of formatting it in a PC, formatting is the same no matter where it is performed, except when done in the aircraft it also sets up all the directories that the camera uses. As to the card, the PNY is suspicious, get a Sandisk Extreme series card if you want reliability. |
