Can't move or copy files from internal storage.
104 5 2017-8-6 00:02:31
fansf5257931
Beginner
Flight distance : 10
I like to know when will DJI start working on a fix for the explorer on Crystailsky. I'm able to delete & rename files but when trying move or copy Created Films or Screenshots from the intenal storage to SD card it dosn't work. I even try to connect Crystailsky via usb to my computer and still had no luck in transfering anything from internal storage. You can't even move or copy from SD to SD.
2017-8-6 00:02:31
fansf5257931
Beginner
Sorry couldn't figure out how to delete the attachments.
2017-8-6 00:03:16
Schata
Student Pilot
Flight distance : 207058
CS firmware is full of bugs. Buttons without any function and SD card slots which cannot be used at all. No content can saved to.
2017-8-6 01:09:18
StianGel
Student Pilot
Flight distance : 73205
fansf5257931 Posted at 2017-8-6 00:03
With the current (and previous) firmware i have no problems transferring files between internal memory, SD cards and USB memory.
2017-8-6 03:52:47
fansf5257931
Beginner
StianGel Posted at 2017-8-6 03:52
That's extremely odd..... because I was reading a previous post where some are experiencing this problem and some aren't. I do understand that the CS still have bugs and fixes that need to be worked on. But I'm just not understanding how it works for some and not all if everyone have the same build and updates.
2017-8-6 09:33:08
StianGel
Student Pilot
fansf5257931 Posted at 2017-8-6 09:33
Have you ever done a factory reset?
When connected to PC, did you tap the icon on the CS to enable file transfer?
With the new update i no longer have issues with choppy video.
2017-8-6 13:12:52
Bold Text Color Picture Add Link Emoticon
Verif code Change one
Close
DJI RecommendsPrevious /1 Next
