Landbo
Flight distance : 502792 ft
Denmark
Irate Retro Posted at 2017-8-6 14:52
Yes, if you set your max to 400', then you would only be able to climb an additional 50'. So don't set your max to 400'. Problem solved?
As for your second question, the RC position doesn't affect anything in the least. It's all about the takeoff point and barometric pressure from there.
Sorry, your information is not true. The height you enter is ALWAYS + the height of your take off place. If the take off place is at an elevation of 5000 ft ASL and the maximum height is 400 ft then the limit of the vehicle's flight height is 5400 ft ASL. ASL = Above Sea Level.
Regards Leif. |
