spark remote controller c2 factory reset ?
46512 21 2017-8-6
Hady Esta
Flight distance : 55627 ft
Lebanon
i have received the spark combo , but when i tried to fly the spark from my mobile without the remote controll , i  successfully connected it and flew it with mobile
But my rc is not connected anymore to spark and now its not even binding
i might have pressed a wrong key combination while on the field
How to reset the c2 rc to factory settings ?
Please help
2017-8-6
DJI Diana
Flight distance : 2408 ft
Have you tried to relink the RC? Here is a video for your reference.
2017-8-7
Hady Esta
Lebanon
yes i did several times but radio keep searching the spark without finding it
2017-8-7
Hady Esta
Lebanon
DJI Diana Posted at 2017-8-7 01:14
Have you tried to relink the RC? Here is a video for your reference.DJI Spark - Linking the Remote Controller
Dear Diana
yes i did exactly like in the tutorial but still cant connect rc to spark
spark is connecting to  mobile
rc is connecting to mobile
rc not connecting to spark
i have downgraded spark  and tried nothing happened
i might have pressed wrong button  while i was on the field ( maybe its the cause of the problem )
Is there a way to reset the rc c2 controller .
PS i have also reset spark  wifi
thx
2017-8-7
DJI Diana
Hady Esta Posted at 2017-8-7 02:56
Dear Diana
It can only reset the WiFi. Could you please press and hold the power button of the drone for 3 seconds when the drone is powered on? See if you can hear a beep.
2017-8-7
Hady Esta
Lebanon
DJI Diana Posted at 2017-8-7 19:07
if i press the power button for 3 second i can hear the beep for binding  and red light flashing  and radio beeping in binding mode but still nothing  after a while red light goes from flashing to steady and rc keep on beeping
i tried also to reset the wifi by pressing the power button for 9 second till i hear the DDD and then try to bind again , but still nothing
I also connected spark to dji-assistant and did a successful factory reset but still no binding
I downgraded spark and still no binding
2017-8-7
DJI Diana
Hady Esta Posted at 2017-8-7 21:17
If so, you may need to send it in for diagnosis, please contact the Support to start a case, http://www.dji.com/support
2017-8-8
premium
Flight distance : 2300 ft
Indonesia
HOLD the power button in your RC for 9 seconds. it will reset to factory default
2017-8-18
Dronason
Flight distance : 5689042 ft
Switzerland
Keep the distance between Spark and RC as short as possible, especially if you have a lot of wifi/bluetooth around you.
2017-8-22
fansaee63856
Flight distance : 8409 ft
Lebanon
How to factory reset the aircraft?
2017-8-29
fans3d56bda5
Flight distance : 9692 ft
I bought my controller separately and with some frustration got it to bind with the Spark.  I flew for a few weeks and all was good. I completed the new firmware update last week and lost the binding with the controller and Spark. I have been in discussion with support and tried their suggestions and tried many of the tips that I find in the forums but none have made it work.  I'm sending it in for repair rather than spend more time without success.
One point of note.  I took me a while to recognize that the wifi signal from the controller was not showing up on my phone or on any other device, at any time. No matter what method I tried to connect the controller to the Spark, my thought is if you don't see the RC signal there probably isn't one.  The controller flashes and beeps and gives the impression that it's connecting but it never does.
No RC wifi, no go with the controller.  I can fly with my phone but that's not as much fun.  Anyhow, time to let the factory sort this.
2017-8-29
karlcranny\
fans3d56bda5 Posted at 2017-8-29 06:59
I have been trying to upgrade my Spark Controller firmware for 5 days now and spent 2 hours on chat with DJI with no luck.  The support person said they would contact me by email with some ideas, did not hear back.  I have had a couple of successful flights and love the unit, but the problems are these:
1.  Controller only connects with OTG cable 1 in 50 times.  Thinking firmware update might fix this I get into a loop with the DJIGO4 app that wants to connect to internet for upgrade, but is the unit is connected to Controller wifi.  Disconnect from Controller Wifi and it wants connection to controller, connect to controller and it wants to connect to internet.  Loop after loop.
2.  Use the DJIGO4 App and it recognized the battery for its upgrade but not the controller for its upgrade.  I know that the controller and phone are connected because when I connect them, the phone starts charging the controller.
I have tried multiple cables, OTG and USB, same result.  The most frustrating thing is the lack of support I have gotten.  If I had not had a couple of great experiences with the Spark, I would have thrown it in the trash by now.
No one has even gotten back to me with an offer to send it back.
2017-9-9
Phuong Do
Flight distance : 29800 ft
Vietnam
Hi,try this procedure.it always works for me:
1. Push the 9sec reset on both aircraft and remote control.
2. Connect aircraft with phone only,go out,wait to get GPS locked,then push auto take off.wait a fee second,then land the aircraft.
3. Go inside,link the remote with aircraft again.
Always works for me when aircraft and remote cannot link.
2017-9-9
djiuser_KCWQe4i
karlcranny\@gma Posted at 2017-9-9 15:02
Had similar problem. After numerous heated discussions with DJI they sent me a replacement controller.   Guess what? No WiFi signal from replacement. Spark and flymore package going back to source for refund.  Unfortunately I will lose money since I can't return the accessories I purchased.
2017-9-24
fans1451e6b6
Flight distance : 1198 ft
Serbia
I also have issue with no wifi from remote. Case opened.
2017-9-29
Katinko
Flight distance : 48858 ft
Philippines
Phuong Do Posted at 2017-9-9 15:33
Can you clarify? Do you turn the aircraft off after you fly it?
2017-10-27
Phuong Do
Vietnam
Katinko Posted at 2017-10-27 03:05
yes I do turn off
2017-10-28
Albatros86
Flight distance : 30325 ft
Indonesia
premium Posted at 2017-8-18 05:21
not working to my case (https://forum.dji.com/thread-122970-1-1.html)
2017-12-8
S.J
Flight distance : 322454 ft
Kuwait
Ok guys, obviously the spark and RC will never connect with latest APK version.
Please downgrade the APK version to 4.1.14 and try again...there is no need to send the spark to the factory..you may have more damages during transportation !!
2017-12-8
fans95359f7f
Ukraine
1. Turn off Controller and Spark
2. Turn on Controller
3. Reset Controller (long press for 9 second Power Button)
4. Turn Off Controller
5. Turn On Spark
6. Long press on Battery button for two beeps (6 second)
7. Turn off Spark
8. Turn On Spark
9. Long press on Battery button for three beeps (9 second)
10. Turn Off Spark
11. Turn On Spark
12. Once Again press on Battery button for two beeps (6 second)
11. Then (without turn off) press on Buttery button for 1 beep (3 ceconf)
12. Turn on controller
13. Press tre battons Red Pause + Fn + Right Custom button till you hear short beeps and green sparking light
14. They connected in my case!
Had the same issue with spark. What worked for me after talking to DJI support: when you reset spark's wifi settings with 3 beeps (holding power for ~9 seconds) turn it off immediately once you start seeing spark LEDs blinking green! Don't wait and just turn it off once it starts blinking green. Then, when you turn it on again, give it a few seconds to warm up and start, and hold power for 3 seconds. After that controller pairs to drone no prob in a standard way (3 buttons pressed at the same time). works like a charm.
2019-2-13
djiuser_dU3ljjHyTTHf
Flight distance : 692 ft
Vietnam
fans95359f7f Posted at 2-13 11:20
Hi everyone.
I'm facing the same issue.
I have done the factory reset that was working after that the drone and RC was linked.
But as I conect RC with my phone I had an error message saying the WiFi setting has to switch because I am in a different country and after th drone restart, RC and drone is not connected anymore.
I try to downgrade the application ( android 4.3.14) to (android 4.1.4) and after a new factory reset I was able to link RC to drone and fly with the.
I have send message to support and waiting for an answer.
Regards.
Adrien
2019-4-13
Vietnam
Ok I fly with an old version of DJI go with a lot of bug (4.1.4) .
Anyway... The support says that my phone isn't compatible. Strange because I can fly .
I still have the issue with the latest version of DJI go (4.3.14).
Any update for those who have the same issue ?
2019-4-18
