Controller Button Customisation Not Holding
544 3 2017-8-7
Hioctane Cyrus
Flight distance : 45289 ft
Hi everyone,
Is anyone else having the same issue as me?
I set the two buttons up on my controller in the app and they work fine.
Then the next time I come to fly the options I set for the two buttons have reset and I have to define them again!
It's becoming a little annoying now.
2017-8-7
Rawsome
Flight distance : 230827 ft
are you using the Otg Cable? mine sets it fine and retains it without the OTG, with the cable I have to set it every time.
2017-8-7
Hioctane Cyrus
Ah, that will be it, thanks. Yes I'm using an OTG cable.
Still seems daft that it doesn't keep the settings when using the cable.
2017-8-7
DJI Susan
We do not suggest to use OTG as the function has not been officially tested for now. I would recommend you to connect the mobile via WiFi.
2017-8-8
