Wired Controller
1205 17 2017-8-7
HighCamera
Flight distance : 1213238 ft
Can the controller be hooked to mobile device with a cable instead of the wifi?
2017-8-7
Dave-r
Flight distance : 1214 ft
otg cable i have one looks well
2017-8-7
manfredo
Flight distance : 1891142 ft
Can't speak for non-Apple devices as I have no experience with them but you can do it with Apple devices.  I ordered one of these: https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1 and it worked like a charm, I used regular lightning cable to connect to to my iPhone
2017-8-7
HomePoint
Flight distance : 776007 ft
Non-Apple devices work too.  DJI say all should use with caution, as it has not been tested fully.
2017-8-7
Matioupi
Flight distance : 922569 ft
HomePoint Posted at 2017-8-7 07:58
I'm still wondering what fully tested really means when it comes to Spark...
2017-8-7
DJI Susan
I would not recommend you to connect it via cable as this function has not been fully tested.
2017-8-9
Bradders
Flight distance : 862283 ft
Yes it can using this cable for iPhone http://amzn.to/2wH77Cq or this cable for Android : http://amzn.to/2wsT8Rc
2017-8-9
Adomolis
Flight distance : 219219 ft
Anyone tried connecting to a phone with USB-C ? I cant seem to get any response with OTG to OnePlus 3
2017-8-9
Monochrome
Flight distance : 12710 ft
Poland
Adomolis Posted at 2017-8-9 00:53
Today or tomorrow I will test it but I don't see why it shouldn't.
2017-8-9
Monochrome
Poland
Tried otg c cable from mavic (which is super short) but it worked without any issues.
2017-8-9
Thor1
Flight distance : 196837 ft
it is not recommended but according to Customer service it does not void warranty either. my spark tried to fly away with the otg so i wont use mine until it is fully supported but since DJISusan says, "its not fully tested", then that obviously means they are planning on supporting it very soon so i would wait if i were you.
2017-8-9
Adomolis
Monochrome Posted at 2017-8-9 01:44
Hmm thats strange. What phone are you using just in case?
2017-8-9
Monochrome
Poland
Adomolis Posted at 2017-8-9 02:09
It's LG G6. http://imgur.com/a/aDD8W
2017-8-9
$gambino$
Flight distance : 1563980 ft
Thor i don't think that OTG cable made your spark fly away LOL people fly with otg everyday.... Maybe coincidence because you were using it but I don't think so anyway to the guy with the OnePlus 3 u have to hookup the remote last. So start spark then remote. Wait for the remote light to go green hook up your phone then plug into a remote last. App should start.
2017-8-9
Phuong Do
Flight distance : 29800 ft
Vietnam
Thor1 Posted at 2017-8-9 01:47
Hi, Have you checked the flight log for the flyaway reason. I don't think OTG can cause flyaway. In the following video you can see the guy flew ~3km with OTG, and RTH flawlessly
2017-8-9
Thor1
Phuong Do Posted at 2017-8-9 02:53
Hi, Have you checked the flight log for the flyaway reason. I don't think OTG can cause flyaway. In the following video you can see the guy flew ~3km with OTG, and RTH flawlesslyhttps://www.youtube.com/watch?v=H1fXUiUmw0Y
the first time it worked great. the second and third time not so much. it did not disconnect it just went into atti mode and started to fly away and said it was going to fly through a NFZ. i know the chances of OTG being the cause of this is low but after 70 flights this is the first time it happened and i has no problems before starting to use OTG. so for now i will wait just in case.
2017-8-9
crypiehef
Flight distance : 47707 ft
I have been using my Spark with the OTG cable since day 1 (Iphone 6S). I found the best way to get the cable to work is to first power on the drone. Then power on the controller. Once the controller LED is green then connect the OTG cable to your mobile device. iPhone will pop up a warning that the cable is not supported but it works great in my case. I just ignore the pop-up and hit ok. I use DJI Go 4 and Litchi Beta with little to no problems.
2017-8-9
Adomolis
Monochrome Posted at 2017-8-9 02:09
i dunno, tried everything. My phone is just charging the controller when i connect to it. Tried developers settings. Swithing usb modes. Nothing helps... weird.
2017-8-9
