Aardvark
Flight distance : 384432 ft
Ted11 Posted at 2017-8-8 05:23
Thanks Aardvark, The North marker is incorrect as it follows the display around as I turn it, and the pointer doesn't point in the same direction as the aircraft nose. I have as already mentioned calibrated the aircraft compass through the DJI GO app on the integrated monitor,
I see many videos how to do that, but none on calibrating the display compass, any ideas?
Perhaps you just need to do a figure of eight walk as suggested in this other post https://forum.dji.com/thread-80413-1-1.html
I suspect this may work as is, without having to do much else. I don't have a P4P+ so don't know if there is any specific path it requires for calibration. Switch it on and try the Bumble-Bee dance first.
Edit :- As Labroids says, great care needs to be taken with the aircraft compass, if it's calibrated too often it leads to a higher risk of being badly calibrated (due to local interference). Which can then lead to problems when flying. So get one good clean calibration and stick with that until the system says otherwise.
