Situation: I switched out the origional SD card for another card and it would not work. Mavic gave me "Gimbal Disconnected" error when attempting to fly. Put the SD card that came with the drone back into the Mavic but still only see a grey screen. I reformatted the SD card via my computer but when I put it back in the Mavic, still nothing. Tried to reformat via the app, but the app comes back saying "No SD card." Card is inserted correctly and there is no damage to the gimbal. HELP!!!
Pop the SD card in and out several times.
Works for me when I get this error message.
Make sure that the gold contacts face up and that you hear a faint click when inserting the card.
Insert the original SD card of the drone, then restart the drone, see if it works. Besides, if the drone can recognize the SD card after the restart, please format it via the APP.
DJI Diana Posted at 2017-8-7 19:24
Tried all of the above to no avail. The SD card is inserted correctly. When I go to format via the app, it says no SD card still. Tried formating to Fat32 and ExFat just to see and neither works.. any thoughts?
fans283a1b0a Posted at 2017-8-7 22:18
Take the SD card out, restart the drone, then check if the drone is working properly without SD card. Besides, please provide some screenshots about this issue.
I have the same problem, tried everything above. Suddenly it looked liked it worked.The controller recognized the SD card and i was able to format. But when I restarted everything without changing anything, again the controller didn't recognized the SD card again.
fans70cad27e Posted at 2018-1-8 11:57
I have started to have the same "NO SD Card" problems even with a Scandisc V10 card that I have used in the P4P before and which still has some clips on it. If so many people are having the same fault, even with the best hi spec cards sure;y this must be a software problem?
As a bad effect of this I ended up with all my shoot clips from yesterday on the internal memory of my Android and when I try and get them into my editing suite there are no pictures!!!!
Chris
that's what I had to do Diana, was just about to tell him that, thank you
