Frangu
Flight distance : 19849 ft
XadronsHorizon Posted at 2017-8-7 16:33
Just my 2-cents, but I think this has something to do with the Spark's altitude detection. In the manual, there's a line about how visual positioning systems on page 12 (used when the drone is under ~2-4m) being affected when flying over monochrome surfaces (l.e. the black asphalt in your video). I had a very similar issue to this including the drone descending on forward stick and ascending on backwards stick in the parking lot where I live (also solid black asphalt). When I repeated the same maneuvers on grass (or any other "textured" surface), i have not seen the same behavior again and the Spark seems to hold is position better even at low altitudes. Above that height threshold, the system uses its barometer and (so far) seems to be generally more stable in all axis than near-ground. Also, as to $gambino$'s comment above, I agree that wind disturbances are definitely more noticeable visually since you're so close to the ground. 100ft up, even movements like those would be difficult to spot.
Give it a shot if you get the chance and see if the behavior is repeated over a "better" surface.
Thanks, ill give that a try and see. i have noticed this when its high up also and it worries me like i said the first one did not act this way and wanted feedback to see what you guys saw. |
