jetto black
Flight distance : 202995 ft
DJI Thor Posted at 2017-8-8 23:51
It means the working frequency of both the image transmission and remote controller. If the WiFi is on 5.8GHz, the operating frequency of the drone and RC are both in this channel mode. You can choose a channel with less noise, then the transmission of the image will be more smooth.
DJI Thor, respectfully, could you please confirm your statement? Are the RC-to-Spark and RC-to-Phone connections supposed to be on the same WiFi band? At least for me, this does not seem to be the case.
As far as I can tell, when the RC-to-Phone connection is using 5.8G, the RC-to-Spark connection is using 2.4G and vice versa. This makes a lot of sense for the purpose of avoiding interference, so I suspect this is the intended behavior.
For example, Spark pilots using Android phones in CE countries often run into limited range because some Android phones don't support the correct 5.8G channels (not DJI's fault). This means the RC-to-Android connection is forced to use 2.4G and the RC-to-Spark connection is forced to use 5.8G. This results in reduced control range due to 5.8G power limitations in CE countries. Switching to an iPhone solves this problem as the iPhone supports the proper 5.8G channels, so the RC-to-iPhone can use 5.8G and RC-to-Spark can use 2.4G resulting in much better range. If your statement were true and both links were on the same band, this problem would not occur, as both connections could be using 2.4G.
BTW, this problem doesn't happen in the USA because the 5.8G channel allocations are different, and even if the phone only supports 2.4G, the maximum TX power on 5.8G is higher than in CE countries.
If I am proven wrong I will be happy to correct myself. |
