PolarProSupport
Hi The_Death_Angel,
I saw your post and would be happy to provide a little more information about this for you. Polarizer filters work equally well for both photos and video work, their purpose (and the reason for the rotation) is the removal of glare, lens flares, or other polarized light in your shots. For an example of this in action, hold one of the filters up in front of your computer monitor and begin rotating it - at peak polarization, the monitor will appear completely blank when viewed through the filter.
Polarizers by nature require more setup time and adjustment to get consistent results with, due to the fact that the way the polarization looks is variable depending on the angle of the camera relative to the sun. They can provide absolutely stunning results, however, so I have found the added effort to be well worth it when shooting with my own polarized filters (I fly a Mavic). The question of whether to use a polarized filter should depend on your needs and the amount of time you have to spend on the shoot. If you want something you can simply mount and fly without needing to spend any setup time on, then a normal ND filter would likely serve you better.
In the case of the specific pack you bought, those will be most useful for photos, not because of the polarization but rather due to the high ND values those filters offer. The ND32/PL would be the only one in that pack I would recommend for use when recording video - the 64 and 128 will darken the image by too much to be useful for that. The Artisan and Exposure collections for the Phantom 4 Pro are designed with long exposures in mind, so if you're looking for a more general-use set then either the Vivid or Shutter collections would be the best fit. Should you want to return or exchange this set, please email support@polarpro.com and we'll happily set that up for you.
- Oliver from PolarPro |
